I need to connect a analog amplifier with the analog input 0-10V on my Siemens 1200 PLC (located inside the same cabinet as plc, about 40 cm between).
do i need a shelded cable?
or just RK0,75mm2?
do i use any special color on 0-10V?
I wouldn't think it was necessary to use shielded cable for that length unless there is a great deal of High voltage 3 phase or such right on top of it.
Most Companies use BLUE for DC+  wiring some also use it for the negative side but many use grey.
I wouldn't use black outside of a shielded cable because alot of companies use black for H1 [incoming L1 from outside the panel to the breakers and such].
If you don't use screening you can always twist the two cables tightly together.  It helps minimise pickup.  Obviously not as good as full screening though.
Edited by whyme
Clarrification
