Jay Anthony Posted September 21, 2017 Report Posted September 21, 2017 I want to get values from PLC Omron CJ2M-CPU13 with distance about 100m. PLC has RS232 and USB port, RS232 used to connect to HMI and USB port cant connect with distance 100m. I think i will buy Ethernet module, its ok ? How can i get values from Plc to VBA with Excel ?
gclshortt Posted September 21, 2017 Report Posted September 21, 2017 Hi Jay, What about RS422/RS485 card? CP1W-CIF12 RS-422A/485 Option Board (isolated, max. transmission distance: 500 m) https://www.ia.omron.com/products/family/2712/specification.html Regards,
Jay Anthony Posted September 21, 2017 Author Report Posted September 21, 2017 I'll pass that along to the poster.
tuan.bui Posted September 22, 2017 Report Posted September 22, 2017 Hi gcl shortt, CPU13 cant use Option Board, just CPU3x can. I think it just can use CJ1W-ETN21module. Regards,
gclshortt Posted September 22, 2017 Report Posted September 22, 2017 Hi Tuan, Yes you are correct. The CJ2M-CPU13 will not accept the option boards. Only the CPU3_ will accept the boards. You can use the CJ1W-ETN21 Ethernet module.https://www.ia.omron.com/products/family/1451/ The other option is to use the serial communication.https://www.ia.omron.com/products/family/1651/feature.html RS-422A/485 Port: CJ1W-SCU[]1-V1 500 m max. (total cable length: 500 m max., T-branch branch lines: 10 m max.) Regards,
gtsuport Posted September 22, 2017 Report Posted September 22, 2017 You could plug a CJ1W-CIF11 into the CJ2M-CPU13 RS-232 port. Plugs into an Omron DB9 RS232 port and converts to RS422/485 terminal strip. Just a thought.
Mendon Systems Posted September 22, 2017 Report Posted September 22, 2017 One configuration that hasn't been suggested yet is to replace that CPU13 with a CPU33 and add a CP1W-CIF01 if the HMI doesn't support an Ethernet connection.
tuan.bui Posted September 23, 2017 Report Posted September 23, 2017 Hi gcl shortt, How can i get values from Plc to VBA with Excel ? You know it? Regards,
gclshortt Posted September 23, 2017 Report Posted September 23, 2017 Hi Tuan, Here is a link that will show the Omron Host link Protocol using VBA. http://accautomation.ca/how-to-implement-the-omron-host-link-protocol-part-2-vba/ The CX software also comes with CX Server DDE. This should be on your installation disk. http://accautomation.ca/implementing-the-omron-cx-server-dde-and-excel/ Here are some additional links that you may find helpful: Omron Host Link Protocol using VB 6http://accautomation.ca/how-to-implement-the-omron-plc-host-link-protocol/ Omron Host Link Protocol using VB.Nethttp://accautomation.ca/implementing-the-omron-host-link-protocol-vb-net/ Conditional movement of data using excelhttp://accautomation.ca/excel-conditional-movement-of-data/ Each of these links will take you to a specific post. At the bottom of each of these posts you will see a video also explaining the operation and programming. Hope this helps you out. Regards,
tuan.bui Posted September 25, 2017 Report Posted September 25, 2017 Hi gclshortt, Thank you very much for your support. it is really very helpfull. If I connect directly a USB cable, I'll be the same as the Omron Host link Protocol using VBA ? Regards,
gclshortt Posted September 25, 2017 Report Posted September 25, 2017 Hi Tuan, The USB port is a bus for communications with various kinds of Support Software running on a personal computer. High-speed communications are supported. This is a port connected to Programming Devices only, such as the CX-Programmer. Regards,
tuan.bui Posted September 27, 2017 Report Posted September 27, 2017 Hi gclshortt, I wanna use USB port and connect PLC with OPC Kepwave. It's ok ? Do you know it ? Regards,
gclshortt Posted September 27, 2017 Report Posted September 27, 2017 Hi Tuan, OPC Kepware will communicate either through the serial port or an ethernet port. It will not be able to communicate using the USB port of the PLC. This is mainly dedicated to Omron software only like CX programmer. Regards,
tuan.bui Posted October 7, 2017 Report Posted October 7, 2017 On 9/27/2017 at 4:08 PM, gclshortt said: Hi Tuan, OPC Kepware will communicate either through the serial port or an ethernet port. It will not be able to communicate using the USB port of the PLC. This is mainly dedicated to Omron software only like CX programmer. Regards, Hi gclshortt, Oh. OPC Kepware will not be able to communicate using the USB port of the PLC . How can i communicate using the USB port of the PLC with VBA. Regards,
gclshortt Posted October 7, 2017 Report Posted October 7, 2017 You can use the CJ1W-ETN21 Ethernet module.https://www.ia.omron.com/products/family/1451/ The other option is to use the serial communication.https://www.ia.omron.com/products/family/1651/feature.html RS-422A/485 Port: CJ1W-SCU[]1-V1 500 m max. (total cable length: 500 m max., T-branch branch lines: 10 m max.) Regards, Garry
Crossbow Posted October 11, 2017 Report Posted October 11, 2017 As many have stated, the USB port is for programming, NOT data access. You CANNOT use it with VBA to read controller data.
Berti Baker Posted February 4, 2018 Report Posted February 4, 2018 Hmm. Well with Omron's own CX-Server Lite you CAN read and write data over the USB port from VB/C#. I'm not sure if this is standard or custom protocol, but guess Omron are the ones who know how to do this. Regards BB
