rswolff Posted October 7, 2017 Report Posted October 7, 2017 Does anyone know if there is a method to set limits on a numeric entry when using a Simatic HMI? Doesn't seem to be any properties regarding this on the button. Additionally, is there any way to remove the Hexadecimal buttons on the popup keyboard? None of customers actually use hex.....in fact....in 35+ years no one has ever requested to enter or display hex numbers. Thanks, Bob
slcman Posted October 11, 2017 Report Posted October 11, 2017 You have to set limit in tag. As exemple, in Portal, go to HMI tags folder, then select a tag, goto properties --> range. You can set a constant or tag as limit. Numeric entry doesn't have limit, tag does.
