Hi all,
I am writing a S7 program that contains a couple of SR flip flops. When I try simulating by saving, downloading, monitoring and putting
into RUN-P mode even before I turn on any input, the flip flop looks active.
Any ideas as to why this is happening?
Thanks for reading
One reason can be the use of the same address more than once or using a byte or word.
But without more details it is impossible to help, a screen shot would be useful
Thanks for your reply. I did also consider your point and checked the addresses and they had no relation to the others. This happens when I haven't activated any input at all. Just putting the simulator in RUN-P causes this
The only way i have got around it is kept changing the address until it stops behaving like that. It may also be a software issue.
Here is a screen shot of one I'm currently having problems with.
I appreciate your response.
You are a star. I have now added the Memory BIT and when I did MB0.7 was ticked. I don't know why because I hadn't used that address previously.
I have now unticked it  as seen here. Thanks a lot Boss.
SIM.PNG.dd59847d746403cb51ef1e5ca194202a
I just didn't understand why it was ticked when I opened the MB when I hadn't used MB0.7 anywhere in the program.
Edited by Rflower
Needed to add more.
3 hours ago, Moggie said:
Make sure MB0 is not used by the "clock" memory.
In the PLCSIM window show the status of MB0
Thanks very much Sir.
