I am using a cj1m with an OD203 output and other input and relay output cards.  I want to use this card to feed pulses to a servo motor.  I see from rise and fall times, the upper output limit of the OD203 is ~1 kHz or greater. That should be sufficient. Here is my example.  I adjust my servo to 1000 pulses per rev.  Using the OD203, I want to ramp up to 1 kHz on a signal. The servo is happily spinning at 1 Hz. On a signal change, I want to stop the servo at the next multiple of 1000 pulses within the ACC rate.  The motor may spin 10 revs and stop or 10000 pulses.
Will the card I have work for this application? Can I do this independently with two channels?
Thank you.
Please provide the complete part number of the CJ1M cpu.
Per the W340 manual (Instruction Reference Manual) it appears CJ1M-CPU21/22/23 only support pulse output instructions.
Mine is a CJ1M-CPU13. I now see the problem.
Thanks.
Indeed only CJ1M-CPU2[] series supports PULS instructions since they incorporated a Pulse Output module.
However for low-frequency application like this, you can resort to the TPO instruction. TPO is basically a PWM generator with modifiable period and duty cycle.
Please keep in mind TPO instruction is only supported with version 2 or later processors.
Based on the initial post, I would strongly consider a CJ1W-NC213 module.  This would allow for programming ACC / DEC and position for two axis.
Just my two cents.
I had not really thought about that option.
I just checked:
CJ2M-CPU13 + CJ2M-MD21x  $ 1100.00
CJ1W-NC213  $ 1140.00
So it would be less expensive.
From experience I do know the pulse output rate on the MD21x is much lower than the NC213, but don't think that is an issue in this case.
