graemeian Posted October 30, 2017 Report Posted October 30, 2017 I have a CJ1M-CPU13. It will be used for a prototype and later if successful, a better PLC fit will be employed. This system does not have the ability to drive pulses for servo control. However, will this system relay a digital signal at ~1kHz? I also need the PLC to count the pulses, reset at 1000 and start again continuously and never miss an input pulse. I see that the published transactions giveĀ <15 microsecond decision times. I would think it would be no issue. Thank you.
BITS N BYTES Posted October 30, 2017 Report Posted October 30, 2017 The CJ1M is an old unit. Replacing it with CJ2M-CPU and one or two CJ2M-MD21* Pulse IO Modules is a far better option for High-Speed counters and Pulse control outputs. IMHO you are going to waste a ton of time messing with the CJ1M for your application. My 2 Cents.
