Hello,
I want to regulate the temperature by a thermocouple type T with an OMRON control module TC001 / 2/3 and a CJ2M CPU14 series PLC using CX-Programmer as a programming environment. Could you provide me with an example project?
Thank you for your help.
http://www.omronkft.hu/nostree/pdfs/plc/cs1_cj1/w396-e1-03.pdf
Have a look in the operation manual. The card performs just like a stand alone temperature controller. You are just setting the data throught the assigned addresses.
" The CJ1W-TC Temperature Control Units are Special I/O Units that receive inputs directly from thermocouple or platinum resistance thermometers, perform PID control with two degrees of freedom, and output results through open collector outputs. "
Regards,
Garry
