Just an update to my own post, since I has now solved the issue.
Supplied is a PDF of the complete program if anyone else is looking for a solution to the same problem.
BusOccupied input should be used for multi-converter setups. Supposedly its externally setup to "join" all busy-outputs of these frequency converters with immediate update on both input and output. This is to ensure no two controls try to write/read at the same time.
Other inputs should be fairly self explanatory.
//Regards.
DBoll-VFD_FC51.pdf
MainPLC-VFD_FC51.pdf
