luk2011 Posted November 10, 2017 Report Posted November 10, 2017 (edited) I have 200W - 200VAC : Omron R88D-1SN02H ECT Servodrive and Omron R88M-1M20030T BS2 Servomotor I wish to make myself the connection between Drive and Motor , with self made cables. Connectors ( JAE ) - Japan Aviation Electronics JN6FR02SM1 - 2 pins - brake cable in motor side JN6FR07SM1 - 7 pins - encoder cable in motor side JN6FS05SJ2 - 5 pins - power cable in motor side Molex 55100-0670 - 6 pins - encoder cable connector in drive side - ( IEEE 1394 - Firewire 400 ) https://assets.omron.eu/downloads/manual/en/i823_1s-series_setup_manual_en.pdf http://multimedia.3m.com/mws/media/569007O/3mtm-i-o-interconnect-system-2-0-mm-for-ieee-1394-ts2296.pdf http://www.jae.com/z-en/pdf/MB-0161-1E_JN6.pdf https://industrial.omron.mx/es/media/I586-E1-02_1S-Series_EtherCAT_UsersManual_tcm851-112757.pdf ======================================== How can i know which it's pin #1 from each socket from Drive and Servomotor ? Atention !!! I'm not talking about pin numerotation from connectors which i connect to drive or motor . I wish to know the pin #1 from Drive CN2 socket and from Motor sockets ( power , brake and encoder ) http://www.jae.com/z-en/pdf/MB-0161-1E_JN6.pdf In MB-0161-1E_JN6.pdf you can see the numerotation of pins from "Receptacle" . That means , the "Receptacle" it's that part what is in Omron Servomotor ? Or it's the part of JAE connectors , which it's inside of connector housing ? The question is , how can i be sure i don't make a mistake, and i know the right numerotation of Encoder socket of Omron Drive : CN2 and the right numerotation of Omron Servomotor ( brake , power and encoder cable ) I've found schematics about how to connect the Drive with Motor with power , brake and encoder cables , but i didn't find a pin numerotation of sockets ( drive side CN2 encoder socket and power , brake and encoder from motor side ) I didn't find nowhere the right numerotation of pins from CN2 socket of Drive and from Servomotor sockets ( i find it something from above JN6 series connectors from JAE connectors ) I wish to know where can i find the numerotation of pins from Omron R88D-1SN02H ECT Servodrive and Omron R88M-1M20030T BS2 Servomotor Specially , the Encoder cable numerotation from Drive side and Motor side . I've noticed in attached picture the numerotation from Drive , CN2 encoder socket ( IEEE 1394 - Firewire 400 ) . That's correct ? It's right numerotation ? Edited November 10, 2017 by luk2011
