OMRON PLC with Modbus TCP/IP
I stumbled upon this post while searching for other information. I thought I would reply in case anyone else is searching for this information.
We use the NX1P2 for ModbusTCP all of the time. If you need more information, let me know.
Hello @dbones. We want to read from  NX1P2 using Modbus TCP . What setting needs to be done in Sysmac Studio? we have a pc with modscan software. Please help.
Please help me out over MODBUS TCP IP communication part with NX1P2 controller. I will really appreciate if you can provide me basic and working bunch of code for same.
hi im new using the PLC OMRON, and i would like to know how tu use modbus TCP/IP in this plc NX102-1100, someone have a little example how to used or programming,
thanks for you time and knowledge
Have you ever used a omron CP1L to set up modbus tcp i need to configure it to talk to a igus dryve using modbus gateway
Thanks
On 2020-07-02 at 11:26 AM, nanie1991 said:
Attached is the library for NJ and NX series Omorn plc if want to do Modbus TCP connections.
For some server platform , after configure the MOdbus TCP function block, its better to register related tags at the ethernet setting. Attached are the library and related manuals. Hope it helps.
MTCP_NJNX.slr
MTCP_Server_NJNX_E.pdf
MTCP_NJNX_Client_E (2).pdf
Great help.
MTCP_NJNX.slr
Very Helpful
are you done it. if you done tell how it is
