gamal Posted November 19, 2017 Report Posted November 19, 2017 I have an error message during install GX developer software in my computer "Assign the folder to the network drive or copy from the network to the hard disk when installing the folder from the network (assign the folder shallow hierarchy)" my operating system is win 7 ultimate 32 bit while same program installed successfully with another computer.
kaare_t Posted November 19, 2017 Report Posted November 19, 2017 Did you copy the setup files to your local computer, or did you run them off a network drive/usb? I think you need the setup files to be locally when installing...
gamal Posted November 21, 2017 Author Report Posted November 21, 2017 On 11/19/2017 at 7:46 PM, kaare_t said: Did you copy the setup files to your local computer, or did you run them off a network drive/usb? I think you need the setup files to be locally when installing... Thanks for reply,yes I have setup files on my computer not run via usb or network. Best regards
gamal Posted November 21, 2017 Author Report Posted November 21, 2017 On 11/19/2017 at 7:46 PM, kaare_t said: Did you copy the setup files to your local computer, or did you run them off a network drive/usb? I think you need the setup files to be locally when installing... Thanks for reply,Yes I have copy from setup files on my computer.
kaare_t Posted November 27, 2017 Report Posted November 27, 2017 Try re-copying it to your local harddrive (from CD/USB/Network etc.), make sure you have enough diskspace, and be absolutely sure that you have all the files locally on your harddrive, then try again and post the result(s).
gamal Posted December 6, 2017 Author Report Posted December 6, 2017 On 11/27/2017 at 8:28 PM, kaare_t said: Try re-copying it to your local harddrive (from CD/USB/Network etc.), make sure you have enough diskspace, and be absolutely sure that you have all the files locally on your harddrive, then try again and post the result(s). After follow your advice unfortunately the problem still as it is ,we were reinstall win 7 32bit , but nothing changed . Best regards
kaare_t Posted December 19, 2017 Report Posted December 19, 2017 Sorry for the late reply. Could you take some more screenshots of location, install-progress, error message(s) and so on?
