Hi All.
Wondering if anyone could provide some assistance to a Profibus Configuration issue I am having.
I am using the QJ71PB92V as the Profibus Master in combination with a Q12H CPU.
I have 2 nodes in my configuration- 1 is a  Robot controller- all working correctly (32 words both ways).
The other node is an ET200s (header mfg number: 6ES7 151-1AA05-0AB0) (4 Bytes in/ 1 Byte Out)
The module has been set up with 2 PM-E's, 6x 4DI Cards and x2 4DO Cards- the configuration has has been rechecked against the physical configuration.
When I download my configuration- the node is picked up on the Slave Status as sending and receiving information; but is providing 1 diagnostic message which is "Parameter transmitted by the master is incorrect"
I have downloaded the most recent .GSD file from the Siemens website- I have imported the file and configured and downloaded; but im still faced with the same error.
I have also deleted the entire configuration- and configured the 1st 2 modules (a PM-E and 4DI Card)- physically removed the remaining modules and downloaded but im faced with the same error. So this says to me that it is likely not a configuration issue? Also tried byte swapping- no different.
On the ET200s side- The "BF" is flashing @ 1Hz- everything else is OK. I have also tried power cycling the nodes and master
Any feedback would be appreciated?
Hi Gambit.
Many thanks for your reply.
It has been setup as a Profibus Master Class V1.
As above- I did check the box 'swap io bytes' for the slave specifically- but made no difference. I thought byte swapping only applied Siemens <----> Schneider.
Gambit.
Had left a High Feature in the ET200 from playing last night. Put the original header back in and turning off the DP V1 class has cleared the bus fault.
Many thanks ??.
