flashes Posted December 1, 2017 Report Posted December 1, 2017 Good day I need help regarding the interfacing of OMRON Ethernet Module to Keyence CV-5001 (PLC LINK) any one know the correct setting and procedure regarding this matter. thank you and hoping for your reply
IO_Rack Posted December 1, 2017 Report Posted December 1, 2017 What is the part number of the Omron Ethernet Module? Do you have to use PLC LINK? Ethernet/IP may be a better solution.
flashes Posted December 2, 2017 Author Report Posted December 2, 2017 Omron ETN21 (21mode) I used PLC Link through ethernet connection, pinging the cv5001 had no problem,but it cannot be connected.
IO_Rack Posted December 2, 2017 Report Posted December 2, 2017 Do you have the "CV-5001 Series User's Manual"? Chapter 7 explains the setup including choosing "PLC Link" mode and PLC type. Chapter 10 outlines controlling the system and outputting data with examples. Let us know exactly what you are having trouble with.
