Shoaib Posted December 19, 2017 Report Posted December 19, 2017 Dear All. I am new to mitsubishi PLC. I need to use 6 PID loops in one program. I am using FX3U with 4AD and 4DA. can I use 6 PID loops in one program? can I use PID without Autotunning? waiting for reply. Thanks Shoaib
Clear.Mind Posted December 19, 2017 Report Posted December 19, 2017 Quote can I use 6 PID loops in one program? yes. Quote can I use PID without Autotunning? yes. 1
Shoaib Posted December 20, 2017 Author Report Posted December 20, 2017 Dear Clear.Mind, What will be the effect if I use PID with or without autotune? I am going to control speed of a motor through VSD to control speed of the fan and hence the temperature. temperature is in 4-20mA and MV will also be in 4-20mA. 4 are temperature control loops, 1 pressure and 1 level control loop . please tell me what should we do either manual setting is fine or Autotunning is better? Thanks Shoaib
Pierre DURIEZ Posted December 20, 2017 Report Posted December 20, 2017 dear Shoaib if you don't/can't use autotune, you will have to set the convenient parameters manually. autotune seems not so often implemented in traditional PLC. Depending on the PID loops, you have to consider to control loops from a separate device and make communication between this controller and the PLC. For light loops, a PLC should be enough. Pierre
Shoaib Posted December 20, 2017 Author Report Posted December 20, 2017 Dear Pierre Duriez, in my project I need to use PID loop as there is no any other controller installed. If autotune is not so important then it means that main task is to properly set the P,I and D values manually to get the best result? If I don't use Autotune, may I control the PV in the range of +- 1% of the SV? waiting for reply. Thanks Shoaib
kraykov Posted December 20, 2017 Report Posted December 20, 2017 (edited) Hello Shoaib, Whether you could not use the built-in inverter PID and thus reduce the number of PID regulators used in the PLC? Best regards, Kraykov Edited December 20, 2017 by kraykov
Shoaib Posted December 21, 2017 Author Report Posted December 21, 2017 customer wants me to use PID in PLC not the VFD. so that's why I need to design the PID in PLC
Shoaib Posted December 21, 2017 Author Report Posted December 21, 2017 if I don't use the autotune then i need to put P,I and D values manually? is any other value to enter in any register? waiting for reply. Thanks Shoaib
Shoaib Posted December 21, 2017 Author Report Posted December 21, 2017 is there any email id through which we can get help directly from Mitsubishi for Automation products?
