Hi,
I Have some Problems with this Function Block written in Codesys ST:
Variables:
FUNCTION_BLOCK FB_Powder_Test
VAR_INPUT
    bEnable: BOOL;
    bPowder_On_Button: BOOL;
    bPowder_Test_OnOff: BOOL;
    iTime_Powdertest: INT;
END_VAR
VAR_OUTPUT
    bReset: BOOL;
    iActual_time_powdertest: INT;
END_VAR
VAR
    PowderTest_Ton: TON;
END_VAR
Function Block:
IF NOT bEnable THEN
    bReset := TRUE;
    PowderTest_Ton.IN := FALSE;
    iActual_time_powdertest := 0;
ELSE
    IF bPowder_On_Button THEN
        PowderTest_Ton(IN := bPowder_Test_OnOff, PT := (INT_TO_TIME(iTime_Powdertest) * 1000));
        iActual_time_powdertest := REAL_TO_INT((TIME_TO_REAL(PowderTest_Ton.PT) - TIME_TO_REAL( PowderTest_Ton.ET)) / 1000);
        bReset :=  PowderTest_Ton.Q;
    END_IF
END_IF
and GX Works3
Variables:
bEnable                                  Bit                        VAR_INPUT
bPowder_On_Button            Bit                        VAR_INPUT
bPowder_Test_OnOff          Bit                         VAR_INPUT
iTime_Powdertest                Word [Signed]    VAR_INPUT
bReset                                    Bit                        VAR_OUTPUT
iActual_time_powdertest    Word [Signed]    VAR_OUTPUT
PowderTest_Ton                  TON                     VAR
Function Block:
IF NOT bEnable THEN
    bReset := TRUE;
ELSE
        PowderTest_Ton(IN := bPowder_Test_OnOff, PT := (INT_TO_REAL(iTime_Powdertest) * 1000));
        iActual_time_powdertest := ((TIME_TO_INT(PowderTest_Ton.PT) - TIME_TO_INT( PowderTest_Ton.ET)) / 1000);
    END_IF;
END_IF;
I have this Error:
No.    Result    Data Name    Category    Content    Error Code
1    Warning    FB_Powder_Test    Syntax Check    Convert data type from INT type to REAL type automatically.    0x11042FD4
2    Error    FB_Powder_Test    Syntax Check    Data type of argument does not match.    0x11041F61
