Hi,
I am searching for a  Possibility to Set bits in Set or Reset State. How can i do that?
in Example the Code in LD:
and in ST
EQ_E( Merker79 AND Referenzfahrt_TP_Ein_Aus = TRUE , bDummy , P_Achse_Istpos_pulse , 0 );
PLS( bDummy , Drehrichtung_P_Achse AND M8140 AND Loeschen_Positionszaehler_Achsen AND Startpos_anfahren_nach_Referenzi AND P_Achse_Referenziert = TRUE );
Edited by Levent1970
Take a look at this manual
http://dl.mitsubishielectric.com/dl/fa/document/manual/plc/sh080366e/sh080366ej.pdf
[ST program example 1]
IF M0 THEN
Y0 := TRUE;
END_IF;
The above program is equivalent to the following.
LD M0;
SET Y0;
To avoid the bit device being always ON, change the program as shown below.
[ST program example 2]
IF M0 THEN
Y0 := TRUE;
ELSE
Y0 := FALSE;
END_IF;
(a) LD M0;
OUT Y0;
(b) Y0 := M0;
(c) OUT_M (M0, Y0);
Or
IF activation_tag THEN
Y0 := 1; // Set Y0
END_IF;
IF deactivation THEN
Y0 := 0; // Reset Y0
END_IF;
