minal pai Posted February 3, 2018 Report Posted February 3, 2018 Hello write now i am working with Q6UDEH PLC project in which (nextgen 2000) 6021 card is used for conversion of serial to Ethernet data & vice versa , is it possible by only installing the Mitsubishi serial drivers ?? or can anybody tell me how these Mitsubishi serial drivers works ??
kaare_t Posted February 4, 2018 Report Posted February 4, 2018 It's almost impossible to help you with this little information. The Q06UDEH CPU doesn't have a serial port, so the nextgen2000 obviously doesn't convert the serial CPU-port protocol to Ethernet... Can you be more specific with what equipment you currently have, and also where everything is connected? What is your purpose of "installing the serial driver directly"? What is it that you want to do? What does the system do today?
