See photo, I've used the help feature but it's not helping much..... Especially the ">SFLD 3" command?
Code is linked to a 12 character ASCII input from HMI (which I am extending length to 16 characters), and then sent to a laser controller to mark a part.
Laser.thumb.png.37e4939b88028a5647026548
The C24 module is set to byte processing instead of word.
As for the >SFLD 3 [D9500.D9501............] [H0D] command you will have to consult your laser controller protocol
  • Like 1
12 minutes ago, Stuart_Wales said:
Hi Gambit, what do you mean by C24 module?
QJ71C24(r2 or R4). This is serial communication right?
Ending the string with CR (hex 0D)
Edited by Gambit
The $MOV moves that specific character string ">SFLD 3 " into the D8050. The next instruction WTOB separates each of the characters into its own register, this is repeated with a second set of registers. the MOV H0D is moving a Hex value for a CR into a register. then the last line combines all of the characters back into 1 string of 51 characters.
  • Like 2
Thank you
