Steve Bailey Posted February 7, 2018 Report Posted February 7, 2018 I received the following by PM: Hi Steve, I noticed your name on a post related to a similar message I have: "Error during load; Program folder incomplete. Must reload or restore logic". In difference with the original post, I don't have lost of communication, my problem is that I'm trying to backup the contents of the cpu 351, I went as far as uploading the registers and the configuration but when I tried to upload the logic is when it fails and I get this message, obviously if I try all of them in one shot I got the same message. I'm using LM90 9.04 (DOS version), I tried using VersaPro but it doesn't understand the logic as it is comprised of part SFC and part ladder. I have use my laptop to backup many programs and never have this issue, as a matter of fact, I backed up another cpu 351 right after with no problems, I have also used other pc's with same results. My theory is that someone might have tried to connect with a newer version like Proficy ME and converted the logic so now LM90 cannot understand it. I've contacted GE already and they still haven't got back to me. Any ideas? Thanks for your help. I don't care to respond privately to PMs. I'd rather keep the discussion on the forum so that other people can offer suggestions and benefit form the exchange. Since you mentioned that the program in the PLC is written in SFC, do you have SFC installed on the computer you're using for the attempted upload?
IC_J Posted February 8, 2018 Report Posted February 8, 2018 Yes, sfc is installed on both computers. As a matter of fact I could upload similar programs with both laptops that have LM90 without any problems on other 351 cpu units
Steve Bailey Posted February 8, 2018 Author Report Posted February 8, 2018 The error message seems to indicate that the problem is with the project folder in the PLC and not a problem with the program in the PLC. You could try creating a new project folder, set it up for SFC when prompted and then see if you can upload from the PLC to it. That won't give you the rung comments and variable descriptions, but if it works at least you'll have a backup. I assume everything looks OK in the project file you're opening and trying to upload to?
IC_J Posted February 9, 2018 Report Posted February 9, 2018 On 2/7/2018 at 2:11 PM, Steve Bailey said: I received the following by PM: Hi Steve, I noticed your name on a post related to a similar message I have: "Error during load; Program folder incomplete. Must reload or restore logic". In difference with the original post, I don't have lost of communication, my problem is that I'm trying to backup the contents of the cpu 351, I went as far as uploading the registers and the configuration but when I tried to upload the logic is when it fails and I get this message, obviously if I try all of them in one shot I got the same message. I'm using LM90 9.04 (DOS version), I tried using VersaPro but it doesn't understand the logic as it is comprised of part SFC and part ladder. I have use my laptop to backup many programs and never have this issue, as a matter of fact, I backed up another cpu 351 right after with no problems, I have also used other pc's with same results. My theory is that someone might have tried to connect with a newer version like Proficy ME and converted the logic so now LM90 cannot understand it. I've contacted GE already and they still haven't got back to me. Any ideas? Thanks for your help. I don't care to respond privately to PMs. I'd rather keep the discussion on the forum so that other people can offer suggestions and benefit form the exchange. Since you mentioned that the program in the PLC is written in SFC, do you have SFC installed on the computer you're using for the attempted upload? Hi Steve, Thanks for the reply, I'm pretty sure I created a temp folder already and try to upload to it with no success but I'll try again. I also tried loading the laptop project to another 351 cpu and have no problems viewing it, downloading it to the cpu and uploading it back again to the laptop so I'm very confident the laptop folder and contents are not the problem.
