Daethl Posted February 8, 2018 Report Posted February 8, 2018 Hello, I'm fairly new working with OMRON NA5 and I was wondering: Is it posible to load a pdf file in Runtime so I can see it on screen? I know I'm supposed to load the documents in resources but that would be when I'm programming the project in Sysmac Studio before download it to the HMI (see Image_000 attached), but I have no idea regarding how to load files to the root directory while the project is running I mean, is that function avalieable in the NA5? I think I could use its ftp server but I'm not really sure, I'd appreciate if any of you could guide me regarding this issue or if there is an OMRON manual regarding how to access these directories and such.
innoaloe Posted February 9, 2018 Report Posted February 9, 2018 If we refer to the Manual, then no other way to view PDF documents in NA5 except by pre-load it first to the Resource (basically making a copy of the PDF file inside NA memory). Up until the latest version of Sysmac Studio (1.20 afaik) there is only one command to load PDF file, which is ShowDocument that can only refer to the Resource ID instead of a directory (like USB / SDCard). Oddly enough, if you check on OpenMovieFile command, you can load an "External" Movie files from external storage like an SDCard, but they won't give you this feature for documents Soo.... I will suggest you to try using the ShowDocument command, but change the ResourceID argument with an absolute path, like "\SDCard\MyDoc.pdf" or USBMemory or even FTP if that's fits you better. Haven't tried this yet personally
Daethl Posted February 9, 2018 Author Report Posted February 9, 2018 Thank you innoaloe! I'll try that then and I'll let you know what happens.
Daethl Posted February 12, 2018 Author Report Posted February 12, 2018 (edited) On 9/2/2018 at 8:46 AM, innoaloe said: If we refer to the Manual, then no other way to view PDF documents in NA5 except by pre-load it first to the Resource (basically making a copy of the PDF file inside NA memory). Up until the latest version of Sysmac Studio (1.20 afaik) there is only one command to load PDF file, which is ShowDocument that can only refer to the Resource ID instead of a directory (like USB / SDCard). Oddly enough, if you check on OpenMovieFile command, you can load an "External" Movie files from external storage like an SDCard, but they won't give you this feature for documents Soo.... I will suggest you to try using the ShowDocument command, but change the ResourceID argument with an absolute path, like "\SDCard\MyDoc.pdf" or USBMemory or even FTP if that's fits you better. Haven't tried this yet personally It worked! thank you innaloe. I used the code as you suggested and loaded different files to the sd card and the ftp server (via copy to the usb and filezilla respectively) and it worked without problems. Edited February 12, 2018 by Daethl 2
innoaloe Posted February 12, 2018 Report Posted February 12, 2018 (edited) Wow, that's good to know! Thank you for coming back and telling us about it. Still it felt weird that Omron does not even mention this in their manuals . That, or maybe I am looking at the wrong place Edited February 12, 2018 by innoaloe
IO_Rack Posted February 13, 2018 Report Posted February 13, 2018 I was going to test this yesterday but didn't have time. Very innovative thinking innoaloe! Thanks for testing Daethl! I wanted to do something similar some time ago. The other issue that stopped me was, the NJ can create CSV files but not XLS. The NA5 can read XLS but not CSV.
