planemaker680 Posted March 11, 2018 Report Posted March 11, 2018 Hello all, This is my first post and my question may seem a bit stupid (my background is mechanical). Some of the equipment we sell uses Omron PLCs, I have a legitimate copy of CX Programmer and I am trying to trace lack of an output. I have seen a trace function in PLC programming software years ago (might have been AB). Anyway I have read the CX Programmer manual and cannot figure out if this is possible. What I would like to do is just display the relevant upstream rungs to a specific output and not have to go through the whole program. Is this possible? Any help or advice would be greatly appreciated. Thanks, AJM
Mendon Systems Posted March 11, 2018 Report Posted March 11, 2018 (edited) You need to display the "Address Reference Tool" window on the CX-P screen. Each time you select an object in the program by clicking on it that window will display every program rung which references it. When you click on a reference in that window it will take you to the corresponding rung in the program. Edited March 11, 2018 by Mendon Systems
pfort Posted March 11, 2018 Report Posted March 11, 2018 Usefull shortcuts, depending on what you want to trace: 1:Spacebar 2: Alt+4
planemaker680 Posted March 13, 2018 Author Report Posted March 13, 2018 Thanks for your help. Looks like I will have to trawl through the ladder. The OEM uses a default program for all machines and all options. They just disable functions and options not relevant to the actual machine (permanently off) which leaves a lot of dead rungs to go through depending on functionality.
b.k.n. Posted March 14, 2018 Report Posted March 14, 2018 On 3/10/2018 at 10:05 AM, Mendon Systems said: You need to display the "Address Reference Tool" window on the CX-P screen. Each time you select an object in the program by clicking on it that window will display every program rung which references it. When you click on a reference in that window it will take you to the corresponding rung in the program. Yes thats right use your "address reference tool" to see where all it is used. And from there away you need to understand the program well enough to know what code actually will affect that output. My understanding of the "Trace" you referenced(at least for Omron) is a troubleshooting tool to track all the different values that a variable has contained. For example if they are changing so fast you can't see them real time by watching it in the program.
Crossbow Posted March 14, 2018 Report Posted March 14, 2018 When I hear trace, I think sample data over time, because that's what the data trace functions in CX-Programmer and Sysmac Studio do. Searching for an address is more cross reference than trace.
