Hi
Can any member draw  the ladder diagram for this application:
1-O/P pulse high from the photocell sensor to enable rejection system
2-Bottle passes in front of another photocell and after certain time O/P is high"rejection arm"for a certain time.
3-If O/P pulse low from the photocell sensor: nothing to do
Thank you
typical store info and use it later situation
1. you need a way to track information (FIFO or bit array plus another sensor to keep track of conveyor position)
2. every time you do a check, you need to
           a) index your tracker (a bit field or FIFO)
           b) check for cap present and
           c) store result into your tracker (a bit field or FIFO)
3. use information in tracker (single entry) to trigger eject arm.
tracking conveyor position can be done by encoder or sensor counting gear teeth etc.
implementation is yours...
  • Like 1
Hi
1-I will install the rejection sensor and rejection arm followed to detection sensor to simplify the application.
2-rejection arm will be active for certain time after  the bottle detected by rejection sensor after certain time.
Can you draw  the ladder diagram for this application?
Edited by Face Book
Add attached file
any concerns about thing called academic integrity?
here is an example that is 99% complete but there is an intentional bug (or feature) and language is from another PLC so you still have to do something....:-)
  • Like 2
Hi
Thank you very much for your support.
1-Sorry,Iam not understood all the ladder diagram.
Can you explain it?
2-Where are the signals of sensor tracking position and rejection sensor  in the ladder diagram?
3-What do you mean by conveyor indexed signal?
Edited by Face Book
1-Sorry,Iam not understood all the ladder diagram. Can you explain it?
i did ... in previous post. the whole point is that you should not focus on this ladder diagram and try to make your own. also syntax will be different. tip when programming, you need to understand what happens with information/data that you work. if you cannot explain it on paper, you don't understand it.
did you read at all...? IN1 and IN2 are in the diagram.
since you don't do decision making and processing on the spot, information need to be stored for later use (reject station is some distance away from station where you check for cap). this means that stored data (in PLC memory) need to corelate with physical situation you are looking at (bottles on conveyor and their position and their status to be rejected).
so let's suppose we have bit field (i used an 16-bit integer which ws sufficient in this case).
i am showing TWO bit fields here, first one represents bottles on conveyor, second one only shows locations that need to be rejected.
in ladder example above, i only use the second one (that is all that we really need to know in this case).
suppose no bottles need rejecting, then data will look like:
0000000000000000 ' no bottles present (just used for illustration)
0000000000000000 ' no bottles need to be rejected yet (this is our tracker)
          |______' reject position
after while it may looks something like this (i choose to track bottles as if they were moving to the left - new bottles are inserted on the right side):
0000000110101111 ' 7 bottles present, there are some gaps in bottle stream
eventually we may encounter bottle that has no cap or it has wrong cap
0000011010111111 ' 9 bottles present, there are some gaps in bottle stream
0000000000000001 ' bottle detected that will need to be rejected
but we need to wait until reject reaches certain position (this is why we must track conveyor)
0011010111111101 ' bottles keep shifting, there are some gaps in bottle stream
0000000000001000 ' bottle that will need to be rejected has traveled, information about reject is shifted in memory to keep track of the bottle position in the stream
Eventually bottle to be rejected WILL reach our reject station:
1101011111110111 ' bottles keep shifting, there are some gaps in bottle stream
0000000000100000 ' reject reached reject station - KICK IT OUT, NOW!
  • Like 2
you are welcome. depending on used PLC, instruction set will differ. specialized instructions are vendor specific so i tried making an example using only the most basic instructions. this should make porting to other platforms simple but it adds some restrictions of course (here it is size of word). nevertheless, idea is to learn concepts. once you can represent data in a form that corresponds to real world, you can use it any way you like.
good luck...
  • Like 1
here is slight tweak since most PLCs do not have TT bit (timer timing). Instead of TT,  here we use DN bit (timer done).
also a bit of comments are added... good luck anyone
  • Like 1
