andrei.apopei Posted April 3, 2018 Report Posted April 3, 2018 Hi, We are trying to connect a Wenglor camera to an Omron NX1P2 PLC via Ethernet/IP. We can program the camera to output different variable sizes, and we managed to do it via Profinet: From Siemens: From Wenglor: How can we do the same for OMRON? Via Sysmac/Network configurator? The default setting has input size 4 and output size 1, which are from 0010 Slot_1 and 0011 Slot_2. I can see the availability of 0012 Slot_3 up to 0015 Slot_6, how can I make use of them? The EDS file doesn’t seem to describe the part as much as the GSDML. Network Configurator Thank you, Andrei
Crossbow Posted April 13, 2018 Report Posted April 13, 2018 That's a question for the manufacturer, not for Omron. Can you change the sizes on that screen you showed?
andrei.apopei Posted April 16, 2018 Author Report Posted April 16, 2018 (edited) Of course, what would you like to see? Edited April 16, 2018 by andrei.apopei
Crossbow Posted April 16, 2018 Report Posted April 16, 2018 What I mean is not what I want to see, it's can you edit those fields...
