Eric Miller Posted April 17, 2018 Report Posted April 17, 2018 (edited) Does anyone know if it is possible to test RS232 communications across a virtual serial port(or any other options) using CX-Programmer? I have to go do a start-up on a unit and I will not be able to get my hands on any of the the devices until I actually go out to the customers facility, so I would like to test the programs and communications settings between the 2 devices somehow here at the office before I go out to the customer faclities... It will be an Omron CP1H PLC communicating with a Beijer touchscreen via RS-232. I believe i just need a straight DB9 cable with a Null Modem Adapter (not sure of any dip-switch settings yet?). The Beijer touchscreen has an Online Simulator (screenshot attached) that lets me choose the com port to use for the communications, which I was hoping to use to communicate with CX-Programmer (screenshot of serial settings also attached) Touchscreen: BEIJER PWS6710T-N LINK to website PLC: OMRON CP1H-X40DT1-D with a serial/RS232 adapter: OMRON CP1W-CIF01 Not sure what all details would be needed for this, so if i missed any let me know! Thanks! Eric Edited April 17, 2018 by Eric Miller
gtsuport Posted April 17, 2018 Report Posted April 17, 2018 The Omron 9 pin pinout is NOT standard. See the attachment. You will need build or purchase a cable from Beijer
Eric Miller Posted April 17, 2018 Author Report Posted April 17, 2018 (edited) ok, I think I found the cable that I need? It is a Beijer CAB30. I will have to call them to confirm tho! I attached some info for that cable, haven't been able to find a pinout for it yet... I will take some connectors to make my own cable as well, just in case Does Omron just need the RX and TX pins connected? or does it need all signals to communicate? Thanks for that info! Edited April 17, 2018 by Eric Miller
Albert Faller Posted August 21, 2018 Report Posted August 21, 2018 I guess Eltima's Serial Port Tester can help.It supports virtual COM ports monitoring and allows to customize serial port preferences.
zimmerMan Posted January 17, 2019 Report Posted January 17, 2019 (edited) There are several hardware options, but what I understood for sure is that with a software solution it will be easier and faster for me monitoring the connections COM port. You try to connect a couple of times with the help of serial port analyzer and you will understand what I am talking about. Edited January 21, 2020 by zimmerMan
