Babyblue10 Posted April 26, 2018 Report Posted April 26, 2018 I have this module that is currently polling some modbus adddress. Problem i am facing is everytime this module is power cycle, i have to manually on back the communication via the function utiliy. how do i auto start this communication?
collinsd70 Posted April 28, 2018 Report Posted April 28, 2018 (edited) If you are referring to ‘starting’ the Modbus TCP card after a powercycle... This can be started via the utility or via the User Program. I dont know about the Modbus cards but normally the start request in an Intelligent Module (32 bit) is the first output bit of the slot number- so for example if your card is in slot 0- then your start request signal will be Y0 (you can also analyse the inputs X0-X1F for module state before sending the start request). Edited April 28, 2018 by collinsd70
Babyblue10 Posted May 3, 2018 Author Report Posted May 3, 2018 meaning y0 i need to enable so that everytime power cycle the module will auto start?
collinsd70 Posted May 3, 2018 Report Posted May 3, 2018 (edited) Babyblue10 According to the QJ71MB91 User Manual- your start request is sent via Bit 5 so at starting X/Y 0000- your address will be Y4. See the attached diagram which shows your process flow and signals to analyse. Cheers. Edited May 3, 2018 by collinsd70
Babyblue10 Posted August 8, 2018 Author Report Posted August 8, 2018 Meaning need to do some program to on it? But the modbus is at rio rack? Any ways to save the ram?
Crossbow Posted August 9, 2018 Report Posted August 9, 2018 It doesn't matter what rack it's in, you have one CPU and one program. The card doesn't have RAM to save, it's told what to do by the controller.
collinsd70 Posted August 10, 2018 Report Posted August 10, 2018 (edited) BabyBlue10. You need to write some level of user program to control this module and handle additional information you require. When your starting the modbus card from the configurator tool- in effect it is toggling the start bit (as we said earlier 'Y4'). Writing this sort of command into your program saves you from starting in the configurator tool every time the CPU is reset or the Card stops. This is a standard protocol across most of the Q-Series intelligent modules. Edited August 10, 2018 by collinsd70
