Guest lenaball Posted December 17, 2002 Report Posted December 17, 2002 How to make my own cable to connect pc with Plc Shilin. I not have the Cable . Help me. thanks. Best Regards. My email: lenaball@netcenter-vn.net Quote
Guest Rother Posted December 18, 2002 Report Posted December 18, 2002 If the cable you need is the same as the Mitsi FX series then you are probably out of luck The cable is not a pin to pin cable. It has a protocol covertor within the connector. The cable you need is an SC-09 Quote
Paul416 Posted December 19, 2002 Report Posted December 19, 2002 You can construct your own SC-09 cable, its quite simple, I've made one myself. Take a look here for a cable diagram http://www.btinternet.com/~paul416/PLC/sc09.jpg The converter is just a rs232 to rs422 converter. I used one of the inline converters avaliable from RS Components (UK). Quote
Guest DINH TUAN Posted February 25, 2003 Report Posted February 25, 2003 DEAR ALL I HAVE SEEN WEB ADDRESS. BUT I DON'T KNOW WHAT THE NAME OF THE IC IN DIAGRAM. ANY BODY CAN HELP ME? HOANG DINH TUAN FROM VN Quote
Guest DINH TUAN Posted February 25, 2003 Report Posted February 25, 2003 DEAR ALL I HAVE SEEN WEB ADDRESS. BUT I DON'T KNOW WHAT THE NAME OF THE IC IN DIAGRAM. ANY BODY CAN HELP ME? HOANG DINH TUAN FROM VN EMAIL : hoanggia@saigonnet.vn Quote
Sergei Troizky Posted March 7, 2003 Report Posted March 7, 2003 Two receivers and two transmitters on the PC side of the converter is one piece MAX202 from Maxim (RS232 to RS422 converter). On the PLC side there are two differential driver/receiver pairs. Each is 75179B from Texas Instruments. Quote
Sergei Troizky Posted June 1, 2003 Report Posted June 1, 2003 http://forums.mrplc.com/index.php?act=ST&f=15&t=609 Quote
