antht Posted January 19, 2005 Report Posted January 19, 2005 I am just completed installing a CC-link network with 56 devices. As far as I know it is not possible to program via the CC-link network. Does anybody know of a way to program via the CC-link network. Currently I have to program each device (FX1N) individually. GX Developer does have an option in Transfer Set-up to choose a network route of which CC-link is an option. Does this mean that it is possible to program over a CC-Link network? Any help much appreciated. Anth Quote
panic mode Posted January 19, 2005 Report Posted January 19, 2005 probably easiest and cheapest way is to add one more node to the network - AJ65BT-G4-S3. I never used it with FX series PLCs but that should be no problem: Quote
antht Posted January 19, 2005 Author Report Posted January 19, 2005 I was having a look at this earlier. My concern is that I have a Q02 PLC with 3 CC-link masters, each with 20 FX1N's on. So I ideally would like to upload an FX program through the Q series to a particular CC-link module on a particular master network module. I could plug the G4 in as a device on each network in turn and do the programming but this may not save me that much time and hassle. Quote
panic mode Posted January 19, 2005 Report Posted January 19, 2005 As said, I didn't use FX. I had networks of same PLCs and mix of Q and QnA. With mixed network (Q and QnA) I had no problem accessing all CPUs through PLC programming software (GX Dev) but I could not connect with other products such as MX Components 2.x and 3.x. Problem was connecting with MX to QnA when Q was master (didn't try the other way around). Quote
Guest TheGambit Posted January 20, 2005 Report Posted January 20, 2005 Transparency over the CC-Link network is only supported for the modulair series of Mitsubishi. The FX master and slave do have this feature. However Mitsubishi will be introducing a new FX line this year which will probably have CC-Link version 2. Quote
