Veganic Posted May 16, 2018 Report Posted May 16, 2018 Can the contents of GOT2000 internal registers be retained after power down / power up? Also,and possible related, how do I get a bettery low warning? Finally, what are VGD registers? I've tried the manuals and can't find anything, apologies for such basic questions.
Gambit Posted May 17, 2018 Report Posted May 17, 2018 I don't think so. I would use the latched registers from your PLC. Battery low from your PLC or HMI ? VGD and VGB is for GT Mobile. Webpages in your GOT.
Veganic Posted May 17, 2018 Author Report Posted May 17, 2018 (edited) Thanks for confirming my suspicions. Battery low from the HMI, but it looks like that isn't the issue if the GDs aren't retained. Strangley this PLC has no retentive registers. It has some flash memory you can write to with a special function but that is a bit risky given the possible number of writes. I will use some external memory and a recipe. Webpages? Sounds like too much hard work. Is VNC free on GOTs yet? Edited May 17, 2018 by Veganic
Gambit Posted May 17, 2018 Report Posted May 17, 2018 VNC isn't free neither is GT-Mobile but it is not expensive. It is very easy to create as you make the pages the same way as nomal pages and they can be in other resolution to fit an smartphone or tabled. That's the problem with VNC they never match. Also you can create hyperlinks to webages open documents and call phone numbers etc.
