Theo V Posted May 25, 2018 Report Posted May 25, 2018 Hello all, I need to change the IP setting of a Beijer MAC E1032 text terminal (HMI) without a computer or e-designer software available on location. I know there was in the E100 series a two-button combination to switch manually from run to prog (arrow+home) however it did not work on a E1032 series terminal. This is an other combination but I just forgot what it was because normally I always use the PC for this. Anyone has the answer wich combination it is? Thanks in advance for your help. Best regards, Theo V.
Inntele Posted May 26, 2018 Report Posted May 26, 2018 Hi Theo, For E1000-series the mode is selected by mode switches. http://omniray.ch.sabon.ch-meta.net/tl_files/Katalog/Handbuecher/Steuerungs-UndRegeltechnik/HMI_Bediengeraete/E-Terminal/E1000-Series/HardwareManuals/E1000-Series_ServiceMaintenance_MA00758A.pdf , page 24
Inntele Posted May 26, 2018 Report Posted May 26, 2018 http://www.cdluk.com/cable-wiring-guides/how-to-e1000-hmi-dip-switches/ 1
Theo V Posted May 26, 2018 Author Report Posted May 26, 2018 (edited) Hi Inntele, this is exactly what i need! I will try this DIP switch setting 1000 as soon as i return to my workbench. thanks and best regards Theo UPDATE: Today I've made a test setup on the workbench. The DIP switch settings were a very easy way to change the network settings, worked fine! Thanks again Inntele! Regards, Theo V. Edited May 28, 2018 by Theo V Update on information 1
