thomas1000 Posted May 29, 2018 Report Posted May 29, 2018 Good evening fellow members, I have an application that uses a Q00J PLC and a GOT GS2107-WTBD HMI which has been successfully set up for Ethernet Communication. Ethernet Communication on the PLC is via an E71 Module. I normally use the Beijers HMI's but thought about giving the GOT's a go. In order to download the Operating System and Application Software to the HMI I used an USB Lead for communication. In order to further upload, download or verify the HMI Software I would like to do so over Ethernet. I have tried to toggle between USB and Ethernet but keep on getting an error for Ethernet. In Communication Configuration Settings I have Selected: Connection to GOT: Direct Connection Image PC Side I/F: Ethernet Detailed Setting PC Side I/F: No parameter to select GOT IP Address 192.168.0.20 Peripheral S/W Communication Port 5015. The PC IP Address is 192.168.0.100 and the PLC IP Address is at 192.168.0.1 Any Ideas? I would appreciate some help. Many Thanks.
Gambit Posted May 30, 2018 Report Posted May 30, 2018 Good choice you can do a lot more with GOT's. First Can you ping the GOT's ip adress? In your project go to the GOT ethernet settings => Got ethernet common setting and check if the commport is still set to 5015. last resort turn of the firewall of you PC. maybe this port is being blocked
thomas1000 Posted June 12, 2018 Author Report Posted June 12, 2018 Many Thanks for your reply. Ping is ok. I have comms between plc and hmi but I can't download from pc to HMI on Ethernet. Any ideas
