NgoHoang Posted May 30, 2018 Report Posted May 30, 2018 Dear all! I'm working with PLC Mitsubishi Qn CPU. At the Ethernet Port, I see "CC-Link IE Field Basic" label but I don't know, we can use this port for CC-Link IE Field or not? If we can you, how to config in GX_Works2 Any one used CC-Link IE Field help me to explain about it. Quote
Gambit Posted May 30, 2018 Report Posted May 30, 2018 (edited) CC-Link IE Field and CC-Link IE Field Basic are two different networks. In short. CC-Link IE Field - 1Gbps for this you will need an extra card or if you use iQ-R use a RxxEN CPU. CC-Link IE Field basic -100 Mbps (ip adresses) this can be done via the standard CPU port. You can find these setting in your PLC parameters=> Built in ethernet port settings => CC-link IE Field basic setting (button) If you do not see it update your GX Works 2 Edited May 30, 2018 by Gambit Quote
NgoHoang Posted May 30, 2018 Author Report Posted May 30, 2018 Thanks Gambit! In my GX_Works2, I don't see "CC-link IE Field basic setting" button. I'm using GX_Works2 V1.540N. Can you tell me the Version if I want to use CC-Link IE Field basic? Thanks and best regard! Quote
Gambit Posted May 30, 2018 Report Posted May 30, 2018 Just update to the latest version 1.570 it's free (in Europe..) Are you using a QnU CPU ? Quote
NgoHoang Posted May 30, 2018 Author Report Posted May 30, 2018 Thanks Gambit. I will update to 1.570 I'm using Q06UDV and Q13UDV CPU. Quote
NgoHoang Posted May 30, 2018 Author Report Posted May 30, 2018 Dear @Gambit! Can you share for us the link to download GX_works2 V1.570?! Thanks and best regard Quote
Gambit Posted May 30, 2018 Report Posted May 30, 2018 Sorry to big to post but just register your software on the mitsubishi site and you will get a download button for the latest version Quote
NgoHoang Posted May 31, 2018 Author Report Posted May 31, 2018 Dear all! I upgraded GX_Works2 to V1.570U successfully. And I can config CC-Link IEF Basic. After study some thing, I realize that CPU of PLC always is Master station (we can not config it as Slave station). Any more ideas, please share together. Thanks and best regard! Quote
Gambit Posted May 31, 2018 Report Posted May 31, 2018 So your question is how two connect two or more PLC ? Are they all system Q? Quote
NgoHoang Posted June 1, 2018 Author Report Posted June 1, 2018 Yes, @Gambit! I try to connect 2 PLC Mitsu Q06UDV CPU using CC-Link IEF Basic . In the config window, I can not config the CPU as Slave station. Have you use CC-Link IEF Basic? Can you share your ideas. Quote
Gambit Posted June 1, 2018 Report Posted June 1, 2018 Well you can setup fixed buffer program. FB are available from the mitsubishi site. But as you have two universal CPU why not just use the deicated instructions for reading or writing to another CPU. sp.read sp.write take a look at the manual built in ethernet port Quote
NgoHoang Posted June 4, 2018 Author Report Posted June 4, 2018 Yes, thanks @Gambit With another protocol, I finished. I just want to try CC-Link IEF Basis built-in ethernet port. Now ok, I understood about it. Quote
Gambit Posted June 4, 2018 Report Posted June 4, 2018 The iQ-R and L series support simple PLC communication. This is easy the set-up. No programming code required Quote
GreenMan Posted August 16, 2018 Report Posted August 16, 2018 In the last version of GX Works2 (1.576) the simple PLC communication is available for Q PLC's. Quote
