Only one nb can be accommodated within project mess
  Hii,,
I would like to communicate over 2 screens and 1 plc with ethernet ıp . I would like to add second screen  in the project.      ıts ,showing   this  ''Only one nb can be accommodated within project ''
I can not add the second screen to the project,
there is a sample application below
in this example I do, but it's a  ''only  one  nb  can be  accommodated  within  project  '' message
I , send ,project
How can ı do,
thanks in advance for your help
https://www.myomron.com/index.php?action=kb&article=1554
Best regards
CHINE TRANSPORT LINE.rar
Exactly. One NB-Designer project can only have one HMI definition.
If you want to have another screen, copy the entire project folder of your current project and rename it. Open the new NBP project file and change the communication settings to suit your needs (e.g. the IP Address of the second NB project should be different from the first project).
There is no other workaround aside from having multiple NB project at the moment.
  • Like 1
7 hours ago, tiendattdnb said:
how many HMI I can communication with a PLC CJ2m via ethernet ?
I think this would depend on the communications protocol used and will have to include all other connections. The Ethernet/IP Units Operation Manual W465 gives guidance for calculating the number of connections.
