jydepower Posted June 29, 2018 Report Posted June 29, 2018 Hallo. I think its a little hard to figure out what is what, when it comes to space in a q plc. There are steps, devices, standard ram etc. Usually i only care about steps. But in my latest project im running out of room for device registers. Im using a Q06UDVCPU. The specs states: Program capacity 60K steps (which i understand). Device capacity 424K (40K standard device+384K standard RAM) here i understand and know how to allocate the 40K standard device between D devices etc. But i dont understand the 384K standard RAM. what can they be used for? At the moment im running out of the 40K standard device for D registers, which i use for GOT tags. So im wondering can i use the 384K standard ram for more D devices? If not can i use some sort of memory card for extending the devices? The devices i use for GOT tags does not need to be fast. Its basically a recipe database which takes up a lot of space.
Gambit Posted July 2, 2018 Report Posted July 2, 2018 (edited) Yes you can use tthe standard. All you need to do is create a fileRegister file. PLC parameters PLC files TAB. afte you have done that go to the Device TAB. Now the bottom part is configurable and you can add R,D or W registers. Also the devices amount is just a default setting. If you do not use W registers for instance you can set this to 0 and add this 8K to the D. Edited July 2, 2018 by Gambit
