tonton2 Posted July 30, 2018 Report Posted July 30, 2018 Bonjour, ayant un API (PLC)CP1L-M ,en le connectant avec un HMI samkoon(sk-070HE) ,aucune connexion ne s’établit. google translation having a PLC (PLC) CP1L-M, by connecting it with a HMI samkoon (sk-070HE), no connection is established. HMI(samkoon) CP1l (CP1W-CIF01) 2-RX--------------------------------------------------------------------TX---2 3--TX--------------------------------------------------------------------RX-3 5----------------------------------GND-------------------------------------9 je vous en remercie d'avance .Thank you very much
gtsuport Posted July 30, 2018 Report Posted July 30, 2018 Welcome tonton2, You will need to short pins 4 and 5 on the CP1L end of the cable. Also make sure the communication protocol and baud rate, data bits, stop bits and parity are set correctly on the CP1L. Hope this will help.
tonton2 Posted July 31, 2018 Author Report Posted July 31, 2018 (edited) IHM (samkoon SK-070HE) CP1l (CP1W-CIF01) 2-RX ----------------------------------------------- --------------------- TX --- 2 3 - TX ---------------------------------------------- ---------------------- RX-3 4 | ____ | 5 5 ---------------------------------- GND -------------- ----------------------- 9 Je le fais mais sans resultat : (je l'ai essaye mais sans resultat) voila ce que dit la Notice de Samkoon sur Omron The device driver is used for SK HMI to read and write the data or state of SYSMAC C/CPM/CS/CJ series PLC register. The serial communication connection is established through the serial port on the touch screen and the serial port of SYSMAC C/CPM/CS/CJ series PLC, so as to operate SYSMAC C/CPM/CS/CJ series PLC. Prior to use of the driver, one shall carefully read related technical specifications of the chapter and SYSMAC C/CPM/CS/CJ series PLC. How to establish connection with SYSMAC C/CPM/CS/CJ series PLC 1. Hardware connection Connecting cable: RS232 HMI series touch screen COM1/COM2 SYSMAC CS/CJ 2 RX 2 TX 3 TX 3 RX 5 GND 9 GND Terminal of HMI is DB9F, and that of SYSMAC C/CPM/CS/CJ series PLC is DB9M. 2. Software settings Select OMRON in connection device service. select the corresponding item in connection device service according to the connected PLC model or supported protocol. Ensure that the communication parameters in touch screen connection parameters and PLC station number are consistent with the PLC connected. For settings of the PLC connected, please refer to the technical documents of the SYSMAC C/CPM/CS/CJ series PLC. Default connection parameters of SK HMI Setting item Default parameter value Setting scope PLC type SYSMAC C/CPM Series SYSMAC C/CPM/CS/CJ Series Communication port type RS232 RS232/RS422/RS485 Baud rate 9600 1200/2400/4800/9600/19200/38400/57600/115200 Data bit length 7 7/8 Parity bit EVEN EVEN/ODD/NONE Stop bit length 2 1/2 PLC station number 0 0~255 HMI station number 0 0~255 Supporting function Whether it is supported Off-line simulation Yes On-line simulation Yes Extended mode No 3. Operational register and address range SYSMAC C/CPM Series Register name Address format Input range Remarks IR_Bit dddd.DD 0.0~4095.15 Bit: input/output relay HR_Bit dddd.DD 0.0~4095.15 Bit: hold relay LR_Bit dddd.DD 0.0~4095.15 Bit: link relay AR_Bit dddd.DD 0.0~4095.15 Bit: auxiliary memory relay T ddd 0~255 Bit: status of timer C ddd 0~255 Bit: status of counter IR dddd 0~4095 Word: input/output relay HR dddd 0~4095 Word: hold relay LR dddd 0~4095 Word: link relay AR dddd 0~4095 Word: auxiliary memory relay TC ddd 0~255 Word: value of timer DM dddd 0~9999 Word: common data area SYSMAC CS/CJ Series Register name Address format Input range Remarks CIO_Bit dddd.DD 0.0~3189.15 Bit: core I/O area W_Bit dddd.DD 0.0~6143.15 Bit: work area H_Bit dddd.DD 0.0~511.15 Bit: holding area A_Bit dddd.DD 0.0~959.15 Bit: auxiliary area, read only: 7,168Bit: A00000~A447.15 D_Bit dddd.DD 0.0~32767.15 Bit: common data area T dddd 0~4095 Bit: status of timer C dddd 0~4095 Bit: status of counter CIO dddd 0~3189 Word: core I/O area W dddd 0~6143 Word: work area H dddd 0~511 Word: holding area A dddd 0~959 Mot: zone auxiliaire, lecture seule: 448Word: A000 ~ A447 ré dddd 0 ~ 32767 Word: zone de données commune la télé dddd 0 ~ 4095 Word: valeur actuelle de la minuterie CV dddd 0 ~ 4095 Word: valeur actuelle du compteur CP1L Tcp / Ip Enregistrer le nom Format d'adresse Plage d'entrée Remarques CIO_Bit dddd.DD 0,0 ~ 3189,15 Bit: zone d'E / S de base W_Bit dddd.DD 0,0 ~ 6143,15 Bit: zone de travail H_Bit dddd.DD 0,0 ~ 511,15 Bit: zone d'attente Un peu dddd.DD 0,0 ~ 959,15 Bit: zone auxiliaire, lecture seule: 7 168Bit: A00000 ~ A447.15 D_Bit dddd.DD 0.0 ~ 32767.15 Bit: zone de données commune T dddd 0 ~ 4095 Bit: état du minuteur C dddd 0 ~ 4095 Bit: état du compteur CIO dddd 0 ~ 3189 Word: zone d'E / S de base W dddd 0 ~ 6143 Mot: zone de travail H dddd 0 ~ 511 Mot: zone d'attente UNE dddd 0 ~ 959 Mot: zone auxiliaire, lecture seule: 448Word: A000 ~ A447 ré dddd 0 ~ 32767 Word: zone de données commune la télé dddd 0 ~ 4095 Word: valeur actuelle de la minuterie CV dddd 0 ~ 4095 Word: valeur actuelle du compteur Remarque: d représente le système décimal, la plage d'entrée est 0-9; DD représente 16 bits; la plage d'entrée est 0-15; Mot dans les remarques: représente le registre ne peut être utilisé comme mot; Bit dans les remarques: représente le registre ne peut être utilisé que comme bit; Lire uniquement dans les remarques signifie que le registre ne peut être lu que sans être écrit; Les noms des registres pris en charge par un modèle d'équipement différent peuvent être différents et les étendues peuvent également être différentes. Pour le nom et la portée détaillés, veuillez consulter les documents techniques associés de l'appareil connecté je vous envoie en pièces jointes le protocole utiliser merci beaucoup pour votre aide CP1L_SAMKOON.rar Edited July 31, 2018 by tonton2
tonton2 Posted July 31, 2018 Author Report Posted July 31, 2018 Merci beaucoup de votre aide thank's for your help
