Jay Anthony Posted August 30, 2018 Report Posted August 30, 2018 Fairly new programmer doing first analog section in project at new job. Im using NCF motion with parameter for torque control to send the torque values a+8 (leftmost word) and a+9 (right most word) to CX programmer. From there is where I get confused will I just simply be moving both cio 108 and 109 to to a D register?? or will I have to combine the a+8 and a+9 to make a Dword??? and then taking that value to HMI broken line graph. sorry again for creeping in your inbox but ive been looking online for 6 hours. would greatly appreciate any help
Michael Walsh Posted August 31, 2018 Report Posted August 31, 2018 He would do a MOVL from 101 to a+8 (a is defined in the setup of the NCF Module). In the example below, "a" would be W0 and a+8 would be W8 (if it were the Axis 1). However, he would likely have to do some scaling of the analog value in between 101 and W8 to change 0 - 4000 (guessing analog resolution) to 0 - 100000 (100.000% or up to 300.000%).
