An IP address contains 4 addresses. Dec or hex is just a representation of Bits in word.
What is it you wan to do ? combine 4 decimal values into a double word in which every nibble contains one part of the IP adress ?
And which PLC are you using ?
Edited by Gambit
I am using a Q06UDV
I want to be able to enter the IP address as a word. So I've split my IP Address into 4 different parts, ie IP_Part1, IP_Part2, IP_Part3, IP_Part4.
I am wanting to write that into the FB ModbusTCPClient which is in GX Works 2 Library.
The input will be going to the RemoteIPAddress, which is a  Double Word Unsigned.
So how am I able to take that Hex value and use it for my Remote IP Address in the Modbus TCP Client FB?
I have created my own FB with the Modbus TCP Client within
okay first of all you do not need to specify  D0 D1 D2 etc. Create an array of words Like MyIPadress[0..3]
Then use MyIPaddress[3], MyIPaddress[2],MyIPaddress[1],MyIPaddress[0] instead of Direct adresses.
The Temp variable is a local array of  Word(0..1)
Edited by Gambit
