mahnasr Posted September 12, 2018 Report Posted September 12, 2018 Hello we have afew mitsubishi servo motor in our plant.we had to replace bearing one of them(servo motor) but it seem something wrong.the servo motor dont move at all and some allarm appear in servo drive mrj3. the alarm ara 21,52,51 the question is about pole magnetic detection mentioned in MR COFIGURATOR2 software. is there anybody here who any experienced to align encoder on mitsubishi servo motor with mr configurator. BEST REGARDS.
mahnasr Posted September 12, 2018 Author Report Posted September 12, 2018 HI thank you to quick respond. the dive model is MRJ3B. TNX
Gambit Posted September 12, 2018 Report Posted September 12, 2018 Hmm you're getting overloads. Have you tested the motor free from the machine ?
mahnasr Posted September 14, 2018 Author Report Posted September 14, 2018 yes.we have test it in free run.the problem was persist.we ara absolutely sure pole magnetic detection is require.but we dont know procedure. if you know share it pls. its urgent TNX
FRANK RUIZ Posted October 13, 2018 Report Posted October 13, 2018 On 14/09/2018 at 10:39 AM, mahnasr said: yes.we have test it in free run.the problem was persist.we ara absolutely sure pole magnetic detection is require.but we dont know procedure. if you know share it pls. its urgent TNX Hi could you please confirm part no. of the servo amp, and which motor is it controlling? i.e. HFKP13, with MRJ310A. I will look into it, and ask around team, see if anyone knows anything.
GreenMan Posted October 25, 2018 Report Posted October 25, 2018 Hi Usually this operation is done in an external machine. I do not know if this is possible without this machine?
yurtaev Posted February 14, 2019 Report Posted February 14, 2019 (edited) an older topic but... mitsubishi amps do not perform any pole detection with regular rotary servo motors. for the commutation to be correct, absolute encoder disc has to be aligned correctly relative to the magnetic rotor. otherwise you'll be getting overcurrent alarms. to align the encoder: - connect to the amp with MR Configurator so you can read encoder position counter - block the rotor with DC current from a lab power supply - U-positive, V-negative - loosen encoder disc hub setscrews and rotate the disc so that electrical angle is 150deg and fix the screws e.g. for a 6-pole (3 pairs) motor with 18-bit encoder that is: 262144/3 * 150/360 = 87381 * 150/360 = 36409 so encoder should read somewhere around 36409, 123790 or 211172 Edited February 14, 2019 by yurtaev
