First Posted September 12, 2018 Report Posted September 12, 2018 Hello Can someone please help me make a program to cj1m omron plc. Hardware: cj1m cpu 12 ad041 v1, id211, oc211,od212 I will use the plc to my homebrew setup. I have a solid-state relay which I want to heat water with. I think I need a program with pidat and a tpo instruction. Earlier i have just used pid functionsblock, bit it did not work with the old plc. With omrons pid instruction theres some parameters i need to set. I dont understand how. I guess this is an easy job for you guys?
