bond009 Posted September 21, 2018 Report Posted September 21, 2018 Hello All I am new to PLC programming , i have a question regarding omron PLC and High speed counters. I am using Cp1H-XA model plc . I connected HSC port 0 with a encoder and i was able to get the speed of the encoder using PRV2 instruction. Now i am trying to connect the second encoder from the servo motor that i am using to HSC port 1. I am getting the PV signal using PRV instruction . Is there a way to calculate the speed of the servo encoder connected the HSC port 1 using PRV command , since i can't use the PRV2 command for the servo encoder . Thanks in advance .
innoaloe Posted September 29, 2018 Report Posted September 29, 2018 I don't understand... you can use PRV2 for the HSC0. Why can't you use it on the HSC1 as well?
Sergei Troizky Posted October 2, 2018 Report Posted October 2, 2018 (edited) Because the PRV2 works only with HSC0. The PRV may be used to measure the speed programmatically, with certain limitations in resolution and update period. Edited October 2, 2018 by Sergei Troizky
