Hi guys, I have an M221 and trying to read process data from a HACH controller via Modbus 485.
In the Read_Var function block I need to configure ObjType, FirstObj, Quantity and IndexData. Slave ID is 3 and I am using SL2.
So, say if I wanted to read to following registers,
Register #40001, Data Type Integer, Length 1, Description- Sensor Measure
Register #40005, Data Type Float, Length 2, Description - Sensor Temp
Register #40007, Data Type String, Length 6, Description - Sensor Name
what do I put into the Read_Var function ?
I am completely new to this and it's just not clear to me.
Thanks
John
@JohnB315 For easy example you could config each parameter on %READ_VAR each block as describe as follow
Id: Modbus Slave ID
ObjType: Type of data that you read
0 - Read 4xxxx address
1 - Read 1xxxx address
2 - Read 0xxxx address
3 - Read 3xxxx address
FirstObj: Which first register at you read (40001 means Holding Register at register 1)
Quantity: number of register that you read
IndexData: Which %MW number that you need to collect data (such as 1 means use %MW1)
If you have understand concept you can use one %READ_VAR block to read data from device by change FirstObj, Quantity and IndexData by use %READ_VAR0.FIRSTOBJ, %READ_VAR0.QUANTITY and %READ_VAR0.INDEXDATA
  • Like 1
Thank you Wasan, I couldn't have asked for a better explanation.
It worked but I had to offset the address by -1 (40001 = 0, 40002 = 1 etc.) to get a response otherwise it will return an error.
Now, the next stage of my confusion, the value in the %MW I get back is random, anything from -322xx to +20000 or 30000. I was expecting something in line with the actual sensor measurement (pH), or do I need to scale it like a mA value ? If so could you please tell me the steps involved ?
Also, is there a simple way to view what value is in a %MW while I am online during testing in somachine basic?
You use animation tables to view values online
Also it could be that the byte order is swapped around of the register you are reading. Try reading a register which has a constant small value in like date or something to do your tests
  • Like 1
Thanks cHud.
So, a little update, I have managed to figure out how to display any floating point variable. Take Register #40005, Float, Length 2, according to slave's Modbus map.
First, the ObjType is 0 - to access the 4xxxx registers like Wasan said.
Then, in my case #40005 - sensor temp. I needed to offset by -1, so FirstObj will be 4.
Quantity - the no. of %MW needed, 2 in this case, I used %MW0 and %MW1, IndexData is the starting point, %MW0
Now, I finally realised I need to look at the value of both memory locations combined, either a double or floating word, %MD or %MF
%MF0/%MD0 = %MW0 + %MW1, -----  %MF1/%MD1 = %MW1 + %MW2
%MF2/%MD2 = %MW2 + %MW3  ----  %MF3/%MD3 = %MW3 + %MW4 etc.
%MFx or %MDx = %MWx + %MW(x+1)
All I need to do is put the corresponding %MF in the animation table and boom....there's the sensor reading.
Following on from that, can anyone tell me what to do with  Register #40007, Data Type String, Length 6 ?
@JohnB315 For string variable you should use Animation Table to show them by Example I have input "TEST STRING" to M0 for 10 words by use %MW0:10 = "TEST STRING" in operation box.
M221_String_01.thumb.jpg.d5591e412b36207
Then I create animation table for %MW0 to %MW10 then right click at %MW then select ASCII.
M221_String_02.jpg.e354abf8a2950b551aa7b
They will show data in ASCII string by start from right to left and for each %MW can collect 2 character.
M221_String_03.jpg.3d56eee458bd7318cfd5b
