Modbus addressing in Weintek HMI to poll data from Temperature sensor through RS485. In my system i have connected Temperature sensor to I/O Scanner has output in terms of RS-485 which directly connected to COM3 Port pin. No. 6 (as Negative) & 9 (as Positive) of HMI (Model No: MT8071iE) and HMI connected to PC via ETHERNET.
I want to read temp on HMI screen via MODBUS protocol.
So, can you please provide me instruction about addressing of MODBUS register in Easy-Builder Software so can read data of corresponding register. Because when i do compile i got an error like " Device no Response".
I hope i will get reply from your side as Fast as possible to overcome this problem.
Thank you.
Thank you.
Do you mean you need to setting MT8071iE to be Modbus Server for use other PC to communication with it
or use it to receive data from Temperature Sensor?
@rohandarji you should config communication parameter to match with your Modbus I/O device first.
MT8071iE_Modbus_RTU_01.jpg.d044947ea62fd
then create numeric display and select it to config data.
MT8071iE_Modbus_RTU_02.jpg.9943b6e1c4a86
Then disable allow input and config Modbus register that you need to read and click OK after that compile program to HMI.
Edited by Wasan
@rohandarji I mean what Modbus RTU device that connect with Pt 100 sensor. I need to know about its communication parameter.
Are your Pt 100 sensor communication parameter are 9600 8 even 1?
If you can use Modscan32 to read data from sensor you could connect with HMI or Baseblock too.
@Wasanabout communication parameter i attached one screenshot of baseblock for serial communication.
Yes, i data should be shown on HMI or Baseblock but i shouldn't. I cant find the my mistake so if you can help me to tuck out out of this problem then it would be pleasure for me.
Thank you in advance.
@Wasan Thanks.
It was just silly mistake had been done by me in wiring. And as far as i m using RS 485, i am not getting data on both PC as well as HMI. Either on one i can fetch that.
I do some changes in software configuration of Addressing, i mapped MODBUS address into local HMI(LW).
  • Like 1
