marcunni24 Posted November 21, 2018 Report Posted November 21, 2018 Hello all, I´ve seen quite a number of similar posts regarding this topic, but none seems to address this problem in particular. I have an FX3G-40M, with a FX3U-ENET module. I could establish a successful connection to the PLC via RS232. My problem arises when trying to configure the ethernet module (which I want to use for remote monitoring of the PLC program). I've followed every step in configuring the connection. But when I attempt to do the WRITE operation (via RS232), I get the following indication: "The module which supported this function is not found. Please execute again after confirming the module". I can ping the module (as it has the factory IP 192.168.1.254), but can´t seem to download the configuration properly. When I plug the Ethernet cable, a green led lits up, and another one starts blinking. I´ve found numerous posts regarding this issue, but all of them had a FX3U-ENET-L module. (And the solution was simply to use another configuration software). The software I'm using: - GX Developer-FX Version 8.91V - FX Configurator-EN Version 1.30 Any hint you can give me of what can be causing this issue, will be very much appreciated. Kind Regards Martin
Veganic Posted November 21, 2018 Report Posted November 21, 2018 (edited) Do you have any other extension units? Edit: are you sure the default IP address is 192.168.1.254? Edited November 21, 2018 by Veganic
marcunni24 Posted November 21, 2018 Author Report Posted November 21, 2018 Hello Veganic, Yes, the PLC has other extension units. In order FX3U-485ADP-MB / FX3U-4DA-ADP / FX3U-4DA-ADP / FX3G-CNV-ADP<--(Left Side)<-- FX3G-40M -->(Right side)--> FX2N-8EX-ES / FX2N-8EYT-ESS / FX2N-8ER-ES / FX3U-ENET. Regarding the IP address, I did a network scan, using a direct connection (no router), and that's the address that popped up (also, in the FX-Configurator software, it was the default IP address that appeared). Thanks for the response.
kaare_t Posted November 21, 2018 Report Posted November 21, 2018 Update FX Configurator-EN to version 1.40 (can be found on Mitsubishi's website I believe - you have to register).
marcunni24 Posted November 21, 2018 Author Report Posted November 21, 2018 Many thanks for the responses. I will try and let you know. Regards. Martin
Jim82 Posted July 8, 2024 Report Posted July 8, 2024 Hello! I'm rewoking this topic. I'm using FX Configurator 1.40 and installed the FX3U-ENET on a FX3U-64M I have the same problem, did you find any solution ?
Jim82 Posted July 9, 2024 Report Posted July 9, 2024 I found the problem, i was connecting via an HMI. When I made a direct connection to the PLC it worked.
