PicoIan Posted November 21, 2018 Report Posted November 21, 2018 Hello. Recently, while working in Citect Scada 2016, two issues have popped up that I haven't been able to resolve, mainly, 1. Strings entered into text boxes linked to Unity variables will no longer hold their values, despite previously doing so, and show the entered value for maybe a second before going blank. Of the two issues, this one is the more minor.2. The second issue just started on Monday, and is somehow consistent across 3 Citect workstation despite none of them having internet access or being connected to each other. The issue is that whenever I try to make any changes in Citect's Graphics Builder, I get the error, "Cannot find the library (library name).symbol. The library may have been deleted or renamed. Do you wish to change the link? Along with the options of yes, no, and cancel. Selecting yes leads to it asking where the new symbol is, which I am unable to locate, while selecting no removes all trace of the symbol from Citect, and the popup will keep coming up with more and more symbols missing. I tried to select no, and just re-make the symbols missing, however when I tried to compile hundreds of compile errors popped up, despite the program running fine before making the changes. Selecting cancel just closes the Graphics Builder. If I select cancel and run the project the symbols load just fine, however when in the Graphics builder Citect doesn't seem to be able to find them.Any suggestions would be much appreciated. Thanks
gclshortt Posted November 21, 2018 Report Posted November 21, 2018 http://www.plctalk.net/qanda/showthread.php?t=118411 Suggest to contact manufacturer for the answers. Regards, Garry
Wasan Posted November 22, 2018 Report Posted November 22, 2018 8 hours ago, PicoIan said: Hello. Recently, while working in Citect Scada 2016, two issues have popped up that I haven't been able to resolve, mainly, 1. Strings entered into text boxes linked to Unity variables will no longer hold their values, despite previously doing so, and show the entered value for maybe a second before going blank. Of the two issues, this one is the more minor.2. The second issue just started on Monday, and is somehow consistent across 3 Citect workstation despite none of them having internet access or being connected to each other. The issue is that whenever I try to make any changes in Citect's Graphics Builder, I get the error, "Cannot find the library (library name).symbol. The library may have been deleted or renamed. Do you wish to change the link? Along with the options of yes, no, and cancel. Selecting yes leads to it asking where the new symbol is, which I am unable to locate, while selecting no removes all trace of the symbol from Citect, and the popup will keep coming up with more and more symbols missing. I tried to select no, and just re-make the symbols missing, however when I tried to compile hundreds of compile errors popped up, despite the program running fine before making the changes. Selecting cancel just closes the Graphics Builder. If I select cancel and run the project the symbols load just fine, however when in the Graphics builder Citect doesn't seem to be able to find them.Any suggestions would be much appreciated. Thanks 1. If you use OFS OPC Server I have heard that there are some problem like you. Maybe you should update your OFS version. Please check this link below. http://forums.mrplc.com/index.php?/topic/35250-citecttext-string-to-sql/ 2. You should update pages first by go to Graphic Builder select tools then click Update Pagesafter that compile again. If you still have errors you should check that library that missing are in Project folder or not by check at C:/ProgramData/Schneider Electric/Citect SCADA 2016/User/<current project name>.
