raffles Posted November 25, 2018 Report Posted November 25, 2018 Hi guys! I'm sure I'm missing something as I'm not really familiar with Mitsubishis PLC platform, I'm struggling to get Modbus Comms setup. I'm using a R04CPU, with RJ71C24 serial module. The info available says I should be able to use predefined protocol support for Modbus. The error message from the GP/CPRTCL instruction is H7FF2(32754) which in the manual is "Communication protocol setting error" - "The instruction cannot be executed with the current communication protocol". I have a simple single register write setup to try and prove comms before I actually program the rest of the functionality. I managed to get Modbus/TCP setup correctly through the CPU ethernet port, but this is my next hurdle
kaare_t Posted November 25, 2018 Report Posted November 25, 2018 Hello and welcome! Did you setup the C24 card with "Predefined Protocol" (under Basic settings)? Default is MELSOFT protocol... Did you write the Predefined Protocol to the C24 module (in Predefined Protocol Support Function tool, select "Online->Write to module")?
raffles Posted November 25, 2018 Author Report Posted November 25, 2018 Thanks for the response 1) - yes, screenshot attached 2) - Yes and I confirmed by reading from the PLC back as well. I changed from a single register write to a holding register read and now I don't get the same error. Instead I now get a timeout error H7D12
kaare_t Posted November 25, 2018 Report Posted November 25, 2018 Great! First of all, set "Sumcheck Code = None". You're sure that the slave device is using 8-E-1 bit settings?
raffles Posted November 25, 2018 Author Report Posted November 25, 2018 Thanks -I changed that, I still get the timeout errors. Yes I can setting are correct - I can read/write using my laptop over RS232 So I think I have figured out that I need to write to "Intelligent Function Module", not "CPU Built-in Memory", I no longer have the protocol errors at all, just time out errors which means I have to dig into the wiring again I guess...
kaare_t Posted November 25, 2018 Report Posted November 25, 2018 I just noticed in your previous picture: Change both "Online change" and "Setting change" to "Enable". Regarding memory destination you are correct! But try changing to "Enable" first...
raffles Posted November 25, 2018 Author Report Posted November 25, 2018 (edited) Thank you for your help - we have a successful test, now I can finish the programming at least! I'll need to make some time to invest in some learning for this platform for sure! Cheers Edited November 25, 2018 by raffles typo
