Hi guys,
I just lost the ethernet direct connection, for my CP1L plc.  I was able to use this connection few days back, but yesterday, I did a network reset on my laptop, since I cannot login on our company's wifi,  I did not know that doing this, will remove the plc ethernet setting / connection.
Today, I could not connect to the CP1l plc, even changing ethernet cables to be sure.
I have read from different post, that I could run again the Omron direct ethernet utility tool, but I could not find it in the folders of the CX-One.  I also looked in the installation folders, but also not available there.
Is the utility tool available for download? Or I could run it from the laptop, the utility is already installed, together with the CX-One?
I am using W10, 64 bit,  PLC hardware: CP1L-EM ,  Cx_Programmer : v9.7
Thanks for your help.
Cheers.
Leo
Hi guys,
I already activated again the utility.
The direct ethernet utility tool is located in the folder of Communications Middleware Utilities.
I am now online, using the direct connection option.
Cheers.
Hello, how did you manage because I have the same problem?
I have activated and deactivated the direct connection function and nothing works. he is always stopped
Edited by audetjf
Hi,
In your PC, go to the windows logo ( lower left, left click )
>Go to Omron folder
>Communication Middleware Utilities - click open the folder
>DirectEthernet Utility
Run the application.
Hope this will help.
Are you plugged directly from your PC to the PLC? (no switch/hub in between)
Are you selecting the physical ethernet interface on the direct ethernet utility? (sometimes it defaults to a different interface)
