Hi,
I am having an issue with Citect 6.10.
I am working on a project for addition of New PLC to the existing SCADA.
Currently there are 50 I/O Devices configured in the CITECT SCADA. When I create a New IO Device and Run the Project, Citect Runtime Hangs and closes after some time.
There are 10 projects included in 1 main project (total 11 projects incld main). The communication portion is configured in separate project wherein i tried to create the IO device for my project.
Kindly try to support me in this issue to solve the problem so that i can close out the project.
Citect Version 6.10. Servicepack B
Windows Operating system. Windows 7 32bit with service pack 1
Kindly let me know if in case there is a need for more details.
Regards,
S. Gopalakrishnan
@gopalsrini76 Please tell us what PLC mode that you need to add and your old PLC before. And you should check license do you have that can use with how many tag by check at CiUSafe.exe in Citect installed folder.
Dear Wasan,
Thanks for the reply. However i had fixed the issue.
I tried to add a TCP board when there was one existing. This caused the issue for me when i added an IO Device.
Regards
Gopal
