ProTool Pro/RT
Guest Guest_Wayne
Guest Guest_Wayne
I have a question regarding ProTool Pro. We have a ProTool Pro/RT 128 tag license installed on the PC, with a configured project running. Now we want to make some changes to this project, but are unable to do so. Is it becasue we don't have the ProTool Pro/CS software and license? Pls. advise...
Yes, you need the ProTool Pro CS S/W to actually modify the program. Other than the normal licence you get when you buy any PC S/W, there is no further licensing required for CS. You don't have an authorisation diskette, for example.
R/T is Run Time C/S is Configuration Software You can't modify a program without the C/S and a license. R/T licenses are designed for installation on the end system once the screens are completely designed. This prevents operators from being able to modify the code.
