xcanowarx Posted December 14, 2018 Report Posted December 14, 2018 Hi Everyone, Sometimes I forget to cancel forced bits in omron CJ2M-CPU34 PLC. I want to cancel all forced bits automatically and found something about fins command. I'm now facing difficulty in activating the all cancel forced bits command. (2302) Is there anybody know how to use @CMND command for cancel forced bits? Thank you.
BobB Posted December 14, 2018 Report Posted December 14, 2018 In CX-Programmer open options - PLCs and tick the box to let you know there are forced bits on when exiting - then you will not forget.
xcanowarx Posted December 15, 2018 Author Report Posted December 15, 2018 Hi BobB thanks for your answer. i did this before but our maintenance team members forgot again force bits. I'm looking for the option to cancel with command. We also use Omron NS8 HMI which connect via ethernet. Maybe i can use NS8 HMI for cancel force bits.
Michael Walsh Posted December 18, 2018 Report Posted December 18, 2018 I don't believe the NS can issue the FINS command, but you can certainly do it in the PLC and use the HMI to trigger the code. See below: Note that this just cancels forces, if the ladder (or if it is an input) does not affect the bit in question, it will maintain the same state. 2
Jay Anthony Posted December 18, 2018 Report Posted December 18, 2018 Well, it took a lot of research, but FINS command can be sent by NS Macro (see attached PDF) FINS Macro Scripting 111304.pdf
Michael Walsh Posted December 18, 2018 Report Posted December 18, 2018 Nice @Jay Anthony! I could not find anything on FINS Command in script....Thanks! I am having trouble modifying the MacroINS.def file as it says that I don't have permission. I have tried to change folder Read Only settings and other settings to no avail.
Jay Anthony Posted December 18, 2018 Report Posted December 18, 2018 Make copy of MacroINS.def on desktop Edit with notepad. Save on desktop Rename MacroINS.def in CX Designer folder to OldMacroINS.def Copy MacroINS.def from desktop to CX Designer folder To verify it works, check for FINS in Macro drop down list. Added to pdf above 1
Michael Walsh Posted December 19, 2018 Report Posted December 19, 2018 Thanks! I assumed (incorrectly) that if it would not let me modify the file that it also would not let me rename it.
xcanowarx Posted December 19, 2018 Author Report Posted December 19, 2018 Thank you guys for your answer. Mr. Walsh I tried this plc sofware and It works. But after force canceling last memory value remains. For example I forced 80.01 bit 80.01 value=0 >>>>force 80.01 value= 1 after force cancelling 80.01 value= 1 (force symbol disappear) Do you have suggestions about this?
Michael Walsh Posted December 19, 2018 Report Posted December 19, 2018 On 12/18/2018 at 10:38 AM, Michael Walsh said: Note that this just cancels forces, if the ladder (or if it is an input) does not affect the bit in question, it will maintain the same state. @xcanowarx, that is what I meant by this statement in my original post. The state of the bit will remain in the same state that it was forced to unless the program changes it or it is an input point. There is not really a way around this. Unless you know what bit is forced. if you know what bit is forced, you can force it off using a 2301 command to both force the bit off and then cancel the force.
Jay Anthony Posted December 20, 2018 Report Posted December 20, 2018 The memory tool in CX Programmer has a tab for reading forced status. It takes quite a while to load so I suspect a looping of the variable area read function. See pdf below, VARIABLE AREA ACCESS(.pdf Forced SetReset Execution.pdf
Michael Walsh Posted December 20, 2018 Report Posted December 20, 2018 @Jay Anthony, he doesn't want to use CX-Programmer or a laptop at all. He is looking for a way to do it from the HMI.
Jay Anthony Posted December 21, 2018 Report Posted December 21, 2018 I was thinking of a similar loop in NS.
Michael Walsh Posted December 21, 2018 Report Posted December 21, 2018 Ah, yes. I did not read closely enough.
Ctor Posted July 10, 2019 Report Posted July 10, 2019 On 17/12/2018 at 0:50 PM, Jay Anthony said: Well, it took a lot of research, but FINS command can be sent by NS Macro (see attached PDF) FINS Macro Scripting 111304.pdf On 17/12/2018 at 0:50 PM, Jay Anthony said: Well, it took a lot of research, but FINS command can be sent by NS Macro (see attached PDF) FINS Macro Scripting 111304.pdf Hi Jay, Could you share again this pdf? The link is failing and it sounds very interesting. Thank you very much!!
