AndrejP Posted January 12, 2019 Report Posted January 12, 2019 Hello. I'm trying to connect to Microsoft SQL Server (2008 EXPRESS), but the connection is not working. I have done this in Citect SCADA 2018 without any problems using connection string: hSQL = SQLConnect("SCADA Data Provider=SQLClient.....) How can I connect to MS SQL Server using Citect 6.1? Thanks. Best regards.
Wasan Posted January 12, 2019 Report Posted January 12, 2019 @AndrejP Maybe you should use ODBC connection ad use Cicode like this. hSQL = SQLConnect("DSN=MyDatabase;UID=username;PWD=password"); 1
AndrejP Posted January 12, 2019 Author Report Posted January 12, 2019 Hello. Wasan Thanks for answer. I helped myself with "Database Exchange Controll" to build connection string. The result for successfull connection was (almost the same as yours): hSQL = SQLConnect("DSN=SQLDatabase_Name;UID=UserName;PWD=Password;APP=CITECT;WSID=ComputerName;DATABASE=SQLDatabase_Name;") Best regards, Andrej.
AndrejP Posted January 12, 2019 Author Report Posted January 12, 2019 I have tested this on Citect SCADA 2016. It DOES NOT WORK in this version...
Wasan Posted January 15, 2019 Report Posted January 15, 2019 Is Citect 2016 SCADA are on same computer with Citect 2018 that you described before?
AndrejP Posted January 15, 2019 Author Report Posted January 15, 2019 Hello. The Citect Nexa 6.1 is running on WIN7 machine. The Citect 2016 is on different machine using WIN10 If you are using MSSQL-Wxpress, The connection string using CITECT 2016 is: hSQL = SQLConnect("SCADA Data Provider=SQLClient;Persist Security Info=False;Integrated Security=true;Initial Catalog=mydatabase;User ID=User;Password=Password;server=PC_NAME\SQLEXPRESS;")
AndrejP Posted January 15, 2019 Author Report Posted January 15, 2019 But now I have another problem. In Citect Nexa 6.1 I'm using conn string: hSQL = SQLConnect(" Driver={SQL Server};Server=PC_NAME\SQLEXPRESS;Database=MyDatabase;Uid=User;Pwd=Password) It connects without problems. If I use Querystring: SELECT * FROM MyDataTable it works. I've got values from table. BUT!!! If I use more complicated Querys like Queriing a Subquery (IT WORKS IN SCADA 2016 and in SQL SERVER MANAGEMENT STUDIO): SELECT * from ( SELECT * from mytable ) subquery I've got error: 4501Unexpected text at end of SQL query 'FROM' Does someone have any advise? Thanks. Best regards.
