bijusi2000 Posted January 22, 2019 Report Posted January 22, 2019 Hi all, I got a problem when I attempt to try connecting a GE VersaMax CPU05E to a Siemens KTP600 DP which support RS422/RS485 connection. For KTP600, it does not support the GE Fanuc SNP protocol and any OPC driver. Please give me some ideas. Thanks in advanced.
Steve Bailey Posted January 22, 2019 Report Posted January 22, 2019 Does the HMI support Modbus? The serial ports on the CPUE05 can be configured for Modbus RTU.
bijusi2000 Posted January 22, 2019 Author Report Posted January 22, 2019 8 minutes ago, Steve Bailey said: Does the HMI support Modbus? The serial ports on the CPUE05 can be configured for Modbus RTU. The HMI supports Modicon Modbus RTU. Is it possible to connect with CPU05?
Steve Bailey Posted January 22, 2019 Report Posted January 22, 2019 Yes. You will need the programming software for the PLC. You have to modify the hardware configuration to configure one of the serial ports as a Modbus RTU slave.
bijusi2000 Posted January 22, 2019 Author Report Posted January 22, 2019 7 minutes ago, Steve Bailey said: Yes. You will need the programming software for the PLC. You have to modify the hardware configuration to configure one of the serial ports as a Modbus RTU slave. I will try this method. I would like to set CPUE05 Port 2 (RS-485) as Mobus RTU slave and HMI Siemen KTP600 RS422/RS485 as Modicon RTU master. Is there any wire connection schematic for this?
Steve Bailey Posted January 22, 2019 Report Posted January 22, 2019 Go to the GE support site. The "landing page" for the CPUE05 is located here: https://ge-ip.force.com/communities/en_US/Article/IC200CPUE05-Landing-Page Follow the links to the VersaMax user's manual, GFK-1503E which identifies which signals are carried on which pins (Chapter 4). You may need to set up a free user account to get to the manual.
bijusi2000 Posted January 22, 2019 Author Report Posted January 22, 2019 5 hours ago, Steve Bailey said: Go to the GE support site. The "landing page" for the CPUE05 is located here: https://ge-ip.force.com/communities/en_US/Article/IC200CPUE05-Landing-Page Follow the links to the VersaMax user's manual, GFK-1503E which identifies which signals are carried on which pins (Chapter 4). You may need to set up a free user account to get to the manual. Many thanks, I will try and give you feedback after testing.
bijusi2000 Posted January 31, 2019 Author Report Posted January 31, 2019 @Steve Bailey How can I make one which called "PLC_tag" on Proficy Machine Edition for CPUE05 connecting to HMI? Please tell me that. Previous, when I use Proface HMI and Mitsubishi PLC I don't need making any HMI tag and PLC tag.
Steve Bailey Posted January 31, 2019 Report Posted January 31, 2019 I'm sorry, but I don't know what you're asking. I have never used the Siemens HMI, so I can't give any guidance on that. Modbus address 400000 should correspond to PLC address %R00001. Modbus address 100000 should correspond to PLC address %I00001. Modbus address 000000 should correspond to PLC address %Q00001. Modbus address 300000 should correspond to PLC address %AI0001. 1
bijusi2000 Posted February 1, 2019 Author Report Posted February 1, 2019 14 hours ago, Steve Bailey said: I'm sorry, but I don't know what you're asking. I have never used the Siemens HMI, so I can't give any guidance on that. Modbus address 400000 should correspond to PLC address %R00001. Modbus address 100000 should correspond to PLC address %I00001. Modbus address 000000 should correspond to PLC address %Q00001. Modbus address 300000 should correspond to PLC address %AI0001. This what I need to know. Thank you so much.
bijusi2000 Posted February 13, 2019 Author Report Posted February 13, 2019 @Steve Bailey It works fine. I used a 2-wire Modbus RTU. However, I don't know how to get date/time from CPUE05 to HMI.
Steve Bailey Posted February 13, 2019 Report Posted February 13, 2019 You will have to add ladder logic to the PLC program. Use a SVC_REQ function to get the CPU's clock and calendar data and store it in %R memory. Read the Proficy Machine Edition help file for information on how to set up the SVC_REQ function using function code 7 (Set/Read clock/calendar). 1
